Power steering and cooling system
100,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
JIMMY MCGLAWN
1. Power steering fluid bubbles when car is parked and running. Dealer replaced rack and pinion but says some turbulence is normal as fluid returns to resivor.
2. Where is the AC condensation hose on the car listed above it is the FX 35 model? Getting leak running down over passenger side frame rail.
Oct 17, 2017 at 11:05 PM
  • 55,721 POSTS
First the air is getting into the power steering system becasue the pump is bad allowing air to be sucked in while in operation.
Here is a guide to help you see what needs to be done:
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Here is what it will be like on your car (diagrams below).
Please start a new question for the coolant leak problem.
Let us know what happens.
Cheers, Ken
Oct 18, 2017 at 6:10 AM
