Power steering not working prolery
179,475 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
KVONLUCAS
  • 24 POSTS
When I am making a hard turn or parking, the steering wheel doesn't want to return to the center by itself without me assisting it and it feels loose. And when I'm driving over bumps and when I'm going high speeds like 70, the steering wheel shakes. Is it my power steering rack or the inner tie rod ends?
Dec 10, 2019 at 5:16 AM
Good evening,
This sounds like the steering rack. The fact it does not return is the indicator.
https://www.youtube.com/watch?v=xC4V6vmeAjE
I would have a shop inspect the front end for any loose or worn steering parts for the shaking. It could be the tie rod ends but needs to be confirmed.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Dec 10, 2019 at 6:46 AM
KVONLUCAS
  • 24 POSTS
Thanks, it's not stiff or nothing. On normal steering it will return but like making a hard turn or making a park, it does that.
Dec 10, 2019 at 7:37 AM
Okay, got it. Still the same. That sounds like the internals in the rack itself.
Dec 10, 2019 at 7:58 AM
KVONLUCAS
  • 24 POSTS
Okay and thanks.
Dec 13, 2019 at 3:17 PM
You are welcome.
Always glad to help.
Dec 13, 2019 at 6:18 PM
KVONLUCAS
  • 24 POSTS
And also I had got an alignment and the steering still wanders a bit and when I drive over bumps and imperfections on the road, the steering wheel moves left and right. Bad power steering rack right? Tie rod ends are good.
Feb 16, 2020 at 10:23 AM
Did the alignment shop tell you that the rack is bad? If it is then it cannot be aligned properly.
Feb 16, 2020 at 10:26 AM
KVONLUCAS
  • 24 POSTS
No they didn't.
Feb 16, 2020 at 10:30 AM
KVONLUCAS
  • 24 POSTS
They didn't say anything wrong with the rack.
Feb 16, 2020 at 2:33 PM
I would get a second opinion.
Did they give you a copy of the alignment specs after it was completed?
Feb 16, 2020 at 7:19 PM
KVONLUCAS
  • 24 POSTS
Yes, they did.
Feb 17, 2020 at 4:08 AM
Can you post those specs so I can see them?
Feb 17, 2020 at 4:09 AM
KVONLUCAS
  • 24 POSTS
I have to find the paper but they were within specs. I had seen it.
Feb 17, 2020 at 4:27 AM
I would like to see the specs, both front, and rear.
Feb 17, 2020 at 4:31 AM
KVONLUCAS
  • 24 POSTS
I had lost the paper but they were within specs. I had replaced the rack, tie rod ends, ball joint, and I replaced the intermediate steering shaft and the steering wheel still wobbles over bumps. What else could be the problem? And it still doesn't want to return to center when I make a hard left or right and when I park. I have to steer it into center. What else could be the problem?
Mar 16, 2020 at 7:23 AM
The reason I ask is because the caster is what allows the wheel to return by itself. If it is off, this will be the result.
If the caster is good then it points right at the rack itself.
Mar 16, 2020 at 7:31 AM
KVONLUCAS
  • 24 POSTS
Is it where the shocks and struts be at or it's something else. I do have worn struts and it's clunking.
Mar 16, 2020 at 7:52 AM
It is an angle for the front suspension. that is why I needed to see the results.
They cannot align a car if you have bad struts or mounts. That would make it totally inaccurate.
Mar 16, 2020 at 7:55 AM
KVONLUCAS
  • 24 POSTS
Oh, okay. I have to find the paper. But it was doing the same thing even with the old rack i had too.
Mar 16, 2020 at 8:03 AM
Okay, I read that too. That tells me you have a front end issue.
Mar 16, 2020 at 8:11 AM
