Power steering becomes stiff and sometimes the engine shuts off immediately?
105,000 MILES • 1.5L • 2WD • AUTOMATIC
VICTOR GAMBIZA
My car right P/S on the dashboard and the steering becomes stiff and sometimes the engine cuts off immediately. But that P/S sign won't stay on the dashboard for long. When it goes off, the steering becomes normal.
May 22, 2023 at 5:51 AM
  • 110,248 POSTS
Does the power steering light only come on when you experience the issue? Also, this vehicle has a traditional power steering system. So, the pump is belt driven. Do you ever hear a squealing or noise from the belt when this happens? Is the power steering fluid full?
May 22, 2023 at 1:03 PM
VICTOR GAMBIZA
Yes, the power steering light only comes on when I experience this issue.
May 23, 2023 at 8:39 AM
  • 110,248 POSTS
What I recommend is this. We need to have the can-bus scanned. CAN stands for controller area network. Basically, the different modules are tied together via a few wires so they can communicate with each other. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how to do it:
Let me know if this is something you can do or have done.
May 23, 2023 at 2:12 PM
