power steering
238,000 MILES • AUTOMATIC
BDOT122
i started my van after i got off of work tonight. it was very cold so i sat there to let it warm up. a couple minutes went by and i heard this weird noise coming from the front of the van. i got out and looked under the van and it looked like a hose had busted. and it had a caramel looking fluid come out of it. there was a big pool of fluid. it was too late at night to take it any where so i attempted to drive home. i made it home. on the drive home. i had a hard time turning the wheel. Also it kept acting like the van wanted or was going to shut off as i sat there to let it warm up. So i pressed on the gas a little bit to keep it running. Is my power steering pump out, or could it just be the hose needs replaced?
Dec 10, 2019 at 12:50 PM
Good morning,
Sounds like something failed in the power steering system. You need to have it checked to find out what actually failed and have it repaired.
https://www.2carpros.com/articles/power-steering-problems
This is why it is so critical to have the power steering fluid changed often especially when it comes to wintertime.
Have a shop check it for you and let me know what they find.
Dec 10, 2019 at 6:37 PM
