Power Steering
2005 GMC SIERRA
210,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JAY ZAMORA
My problem started as having heavy resistance when turning left at low speeds/at a stop and normal operation when turning left. I had a mechanic replace the gear box, pump, high pressure line, and install a filter just in case there was anything left floating around. Everything worked great for 3 weeks, then complete power steering failure. Took it back he replaced the pump and the gearbox again. 3 days later complete loss of power steering again. He recommended replacing the ball joints just in case, as that was the only thing he could think of, even though the suspension system checked out okay. During his test drive after replacing ball joints, and the pump and gearbox again, the power steering failed. The power steering system has no electrical connections to the pump or the gearbox. Any ideas?
Mar 23, 2017 at 3:01 PM
HMAC300
  • 48,601 POSTS
only thing I can think of is air or the wrong power steering fluid as it requires gm fluid or equivalent. this also has a certain procedure to bleed the system. One other thing remove the belt and try to pull the pulley off the pump. if it moves towards you the shaft has snapped which has been found by other mechanics in our tips section.
Mar 23, 2017 at 11:42 PM
