Power steering
228,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
MERCYILL
I changed the power steering pressure line and now it's acting as if no fluids are getting pushed through the system at all.
Jan 28, 2020 at 12:24 PM
MASTERWRENCH
  • 258 POSTS
Can you describe what the original issue was with the power steering system?
Jan 28, 2020 at 2:12 PM
MERCYILL
The original issue was that i had a leak in the hose that came from the bottom of the pump.after replacing that hose i am still having issues. Only now its just that it seems the fluids aren't getting through the system at all. I turned the wheel back and forth for close to an hour to work all the air bubbles out but it doesn't seem to get any better and the fluid levels aren't changing either.
Feb 1, 2020 at 3:34 AM
JOETECHPRO
  • 705 POSTS
Hey MERCYILL,
Was the system run with a low/empty fluid level?
Did the power steering fail and the the leak was found after?
If the leaking hose caused the pump to to be run dry you potentially have an issue with the pump itself.
I would also check that you have the correct amount of washers on the fittings for the new pipe. If they are a banjo bolt fitting and you are missing a washer/ to large of a washer you could have a restriction there. Removing the pipe, blowing through it to ensure it is clear and checking your fittings would be a good idea. Making sure the new pipe has not been kinked when installing also.
With the engine running looking into the fluid reservoir is there any movement showing fluid is circulating?
Regards, Joe
Feb 4, 2020 at 3:58 AM
