Power steering is a little stiff?
192,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
DREFERGS
The car is still drivable. Power steering fluid was clear, now it's black. What seems to be the problem? Open the fluid canister and everything is flowing. So why is my wheel a little stiff?
Apr 18, 2023 at 1:56 AM
  • 110,248 POSTS
When you say the fluid was clean and now is black, how quickly did that happen? Also, if it is black, it should be serviced to see if that helps. Keep in mind, the pump may have failed.
Take a look through this link and see if anything helps:
https://www.2carpros.com/articles/power-steering-problems
Let me know if that helps. Also, before replacing anything, I would suggest trying to service the system.
Here is a link that explains how to service one:
https://www.2carpros.com/articles/power-steering-fluid-flush
Let me know if either of the links' help. Also, let me know as much as you can that may be helpful.
Apr 19, 2023 at 10:56 AM
