Power steering pump leak
168,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
STACYLYNN7
  • 32 POSTS
I believe it’s coming out of the pressure line. how would I change that?
May 15, 2020 at 2:31 AM
I attached the process on the line from the pump to the gear. This would be considered the pressure line.
Let me know if you need more info. Thanks
May 15, 2020 at 2:43 AM
STACYLYNN7
  • 32 POSTS
Upon observing and I believe it is transmission fluid coming out of a connection sensor .
May 16, 2020 at 7:11 AM
Okay. Can you get a picture of the area? We need to be mindful that the power steering fluid and transmission fluid are both the same color. Basically they can be easily mistaken for each other so while you may be correct, I just don't want us to get confused on that. Thanks
May 17, 2020 at 10:13 AM
