Power Steering codes P0010 and P0011
69,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROBERT HUGHES2
power steering failure and showing code PO010 and PO011.
Oct 30, 2016 at 12:16 AM
HMAC300
  • 48,601 POSTS
if car was recently jump started then check power steering fuse it may be blown. both of the codes you show deal with inlet and exhaust cam actuators check for clogged screen or bad actuators a mechanic should do this however. Also, a mechanic should scan for codes for lack of steering if fuse is okay.
Oct 30, 2016 at 1:38 AM
