Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Malibu
Steering
Symptoms
Not Working
Power steering keeps failing
2006 CHEVROLET MALIBU
80,000 MILES • 2.2L • AUTOMATIC
LCOLBY28
MEMBER
1 POST
Power steering keeps going out, no place to put fluid. What would be the cause of it to go out and how much would repair be?
Apr 3, 2018 at 3:38 AM
Experienced Mechanic
Good morning.
The fluid fill is on top of the motor. it can leak from many places. it could be the pump, one of the hoses or the rack and pinion assembly.
you need someone to inspect the system for the leak. it is there and will be found just look closely for the leak. the most common area is the hoses.
when was the last time you changed the fluid in the power steering?
Apr 3, 2018 at 11:32 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
