power steering
209,353 MILES • 3.4L • 6 CYL • 4WD • AUTOMATIC
SHICA0986
I recently got the hose and the pump for the power steering done. Today I drove it and it was fine up until around 4:00 pm. I added more fluid and that drained out almost instantly. What could this problem be?
Jul 21, 2017 at 8:33 AM
HMAC300
  • 48,601 POSTS
sounds like someone left an o-ring out or lines loose causing it. see if it is coming out from top or around steering rack by transmission. See picture. then take it back to whoever fixed it first.
Jul 21, 2017 at 8:48 AM
SHICA0986
I actually do not understand the image. Can you explain it to me? It comes from under the car, if that helps I cannot see it come out until I walk away and there is a puddle.
Jul 21, 2017 at 11:37 PM
HMAC300
  • 48,601 POSTS
Sorry, it is not a very good image. where the one arrow is , is your steering box where the line goes in and other arrow is from power steering pump where the connect. if it comes from bottom of car then it could be leaking from box going down or the new line may have a hole in it etc. take it back it should be fixed for free if a defective part or the mechanic messed something up.
Jul 22, 2017 at 12:04 AM
SHICA0986
Okay, thank you.
Jul 22, 2017 at 1:04 AM
  • 55,746 POSTS
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Jul 24, 2017 at 4:42 AM
