Power steering, where is the canister located and how do I check it and fill it?
100,000 MILES • V8 • 4WD • AUTOMATIC
GHUDSON56
Where is canister and how do I check it and fill it? It just stopped working on a u turn. Been perfectly fine until now.
Nov 4, 2024 at 8:58 AM
  • 55,691 POSTS
So this car has an electronic steering system which the motor goes out in commonly. Here is how to change it out. You might be able to disconnect the battery overnight and it might start working again for a while. Check out the images (below). Let us know if you need anything else.
Nov 5, 2024 at 3:21 AM
