power steering leaking
2004 CHEVROLET SUBURBAN
158,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
HARLEY17
fluid seems to be leaking from power steering cap enough that there is fluid on the ground. when pulling off the cap fluid pushes out of the reservoir like pressure is pushing it out.
Jan 3, 2020 at 9:55 AM
MASTERWRENCH
  • CAR REPAIR CONTRIBUTOR
  • 258 POSTS
Pressure build up in a power steering reservoir is generally the result of a plugged cap vent. The cap is designed to vent excess pressure from the system while the engine is running. If the vent is restricted, pressure will build up and result in a leak, typically from the cap itself or the reservoir seals.
Jan 3, 2020 at 6:45 PM
