power steering
140,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
ALEX19899
  • 171 POSTS
How do I replace the power steering reservoir?
Feb 26, 2018 at 10:15 AM
Good morning.
You will need to remove the power steering pump. once the pump is removed. you need to remove the bolts securing the housing to the pump and then remove the housing.
Feb 26, 2018 at 2:47 PM
ALEX19899
  • 171 POSTS
after I replace the pump do I need to bleed the system?
Feb 27, 2018 at 12:22 AM
When you start it up, turn the wheel lock to lock about three times. that will bleed the system.
Feb 27, 2018 at 12:36 AM
