power steering not working after repairing a leaking power steering line
264,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
CASTONEMANUEL
i had a leaking line on my power steering i fixed the line, now i have no power steering.
Jan 16, 2022 at 9:36 AM
  • 110,248 POSTS
After reinstalling the new hose, did you bleed the air from the pump and unit? Also, are there any leaks? Did you remove the accessory drive belt for any reason? Also, is the pressure switch connected?
See pic 1 below.
Jan 16, 2022 at 11:24 AM
