Power steering is making a noise when turning the wheel?
70,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
SKOOTER28
  • 98 POSTS
Power steering is making a noise when turning the wheel and it’s a little stiff to turn.
Aug 13, 2024 at 5:19 AM
SKOOTER28
  • 98 POSTS
This is what it’s doing.
Aug 13, 2024 at 6:05 AM
  • 110,248 POSTS
I did hear it. To me, it sounds like it may be low on fluid. Although this vehicle has electric power steering, there is still fluid in the system.
I attached directions below for checking the PS fluid. It is a little bit of a pain, but it can be done.
Note: If this is an SRT model, these directions are not correct. Let me know if that is the case.
joe
Aug 13, 2024 at 2:19 PM
SKOOTER28
  • 98 POSTS
And this is where the noise is coming from.
Aug 15, 2024 at 4:40 AM
SKOOTER28
  • 98 POSTS
And the fluid seems to be where it needs to be.
Aug 15, 2024 at 12:08 PM
SKOOTER28
  • 98 POSTS
Are you still there?
Aug 16, 2024 at 8:54 AM
  • 110,248 POSTS
Sorry for the delay. I wanted to get clarification on my thoughts of the sound before contacting you.
Both the site owner and I feel this is the electric P/S motor that is making the noise. It is referred to as the EHPS, electrohydraulic power steering pump.
I attached two pics below of its location. Confirm that this is where the noise is coming from and let me know what you find.
Aug 16, 2024 at 2:12 PM
SKOOTER28
  • 98 POSTS
Yes, that’s exactly where the noise is coming from I sent another video of me right at it recording the noise.
Aug 17, 2024 at 12:52 AM
SKOOTER28
  • 98 POSTS
I don’t know if this was normal but as it warms up it gets stiff to turn and I thought about changing the fluid out and flushing it and putting new in.
Aug 17, 2024 at 4:47 AM
  • 110,248 POSTS
The heat is affecting the performance. The pump likely needs replaced, but flushing/changing the fluid is a good inexpensive way to try and eliminate the issue. I'm just not sure it will resolve the problem.
Aug 17, 2024 at 12:11 PM
SKOOTER28
  • 98 POSTS
One more thing, while I was under there, I saw this and it looked like it was going bad i know we replaced the other side but not this one.
Aug 18, 2024 at 8:06 AM
  • 110,248 POSTS
It does look like the rubber bushing is starting to fail. You should likely replace it while you have things apart.
Let me know if I can help and how things turn out for you.
Aug 18, 2024 at 12:37 PM
