Power steering not working, how to check the fuse?
125,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RAMIREZMO13
It doesn't work but how do I check the power steering fuse for it under the hood?
Jan 31, 2023 at 7:46 AM
  • 110,248 POSTS
There are two fuses to check. Both supply power to the P/S control module.
I attached the wiring schematic below, so you have a reference. See pics 1 and 2.
Pics 3 and 4 are the fuse boxes. Pic 3 is the under-hood fuse box. Pic 4 is in the vehicle.
When you check the fuse, it is also important that you confirm there is power to it.
Here is a link that explains how to check:
Let me know if this helps.
Jan 31, 2023 at 11:27 AM
