Power steering
145,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
JOE JONES
While driving the power steering went out. Serpentine belt is in tact, vehicle runs and everything else is fine. Reservoir is now empty and there is a drip right inside the frame inside the driver side tire either from the hose there or something right above it. What has gone wrong?
Thank you
Jun 24, 2017 at 8:04 PM
WRENCHTECH
  • 20,758 POSTS
If there is a fluid leak, then you have to pinpoint the exact source of the leak and repair it, whether it turns out to be a hose, reservoir, rack and pinion or pump.
Jun 25, 2017 at 2:04 AM
