POWER SEATS DO NOT WORK
244,000 MILES • 6 CYL • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
Neither of the seats work, where do I start?
Mar 6, 2020 at 8:45 AM
  • 110,248 POSTS
I would start by checking the fuse in the power distribution box under the hood. See pic 1 for which fuse to check.
Next, if the fuse is good and there is power in and out, check for power to the switch itself. If there is power and they still don't work, you may have a faulty ground. See pic 2 for ground location.
Here are a few links you may find helpful when testing:
Mar 6, 2020 at 1:55 PM
NASER NASER
  • 836 POSTS
Somehow the passenger worked, fuse okay, couldn't find a ground under driver seat. how do i remove the switch to test it?
Mar 8, 2020 at 11:11 AM
  • 110,248 POSTS
If I recall, the switch is clipped into the plastic molding on the side of the switch. Take a look at pic 1 and let me know if it helps.
Mar 8, 2020 at 1:52 PM
NASER NASER
  • 836 POSTS
No this switch is on the too right, pretty much part of the top of the seat, as most Nissan's are, not pike the pic.
Mar 8, 2020 at 2:27 PM
NASER NASER
  • 836 POSTS
What color wire at the switch should have power?
Mar 9, 2020 at 11:14 AM
NASER NASER
  • 836 POSTS
Also there is battery voltage at the main harness going to the module under the seat, but at the switch once i opened it it only gives -2.6v, in minus.
Mar 10, 2020 at 10:24 AM
  • 110,248 POSTS
If the voltage is negative, make sure you don't have the polarity reversed. As far as the power supply, it comes through both a fusible link and a circuit breaker. The wire is white but splices to red before going into the control. Also, the ground between the two seats is spliced and ground is located under the driver's seat, attached to the floor.
See the attached pics. It shows the wiring schematic for both front seats.
Let me know if this helps you.
Mar 10, 2020 at 1:50 PM
NASER NASER
  • 836 POSTS
I will check these wires and supply again thanks. How can I have the polarity reversed?
Mar 10, 2020 at 11:21 PM
  • 110,248 POSTS
If you are using a digital multi-meter, you could have the supply and ground backwards. When the power flows through the meter backwards, it will read negative. It's not hard to have happen.
Let me know and I hope this is helping.
Mar 11, 2020 at 12:09 PM
NASER NASER
  • 836 POSTS
But i used a test light.
Mar 11, 2020 at 12:12 PM
  • 110,248 POSTS
How are you getting a voltage reading from a test light?
Mar 12, 2020 at 9:31 AM
NASER NASER
  • 836 POSTS
I have a test light that comes with a display that shows voltage.it is one of those circuit testers with LCD.
Mar 12, 2020 at 9:37 AM
  • 110,248 POSTS
I don't have one of those, but it sounds like I need one. LOL However, for you to show a negative voltage, power has to be traveling in a reverse manner or there is a draw pulling power the wrong way.
Mar 12, 2020 at 1:02 PM
NASER NASER
  • 836 POSTS
Turned out both the module under the seat and the switch were bad, got them installed and all good thanks !
Mar 13, 2020 at 7:15 AM
  • 110,248 POSTS
Great! Glad it's fixed. Something was back feeding power through your gauge. That is the only way I can think of to get a negative reading. Regardless, I'm glad it's fixed.
Now, I was on the Snap on truck today and they don't have a light like yours, so I have to ask where you got it. LOL
Mar 13, 2020 at 2:43 PM
  • 110,248 POSTS
Thanks!! I like that and feel it is something I need. LOL
Take care and have a good weekend.
Mar 13, 2020 at 3:47 PM
