Where is the Power Seat fuse located?
227,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
KRISTENK16
The driver's seat power stopped working. I cannot move the seat at all. Would this be a fuse issue? Where is the fuse located? In the fuse box, or in the seat control attachment?
Sep 17, 2024 at 3:52 PM
  • 110,251 POSTS
Power to the driver's seat depends on two things. First, fuse J8 in the under-hood fuse box (40 amp), provides power to a 25-amp circuit breaker. That sends power to the seat switch.
Both the fuse and circuit breaker are located in the same power box under the hood. If you look below, I attached a couple pictures to help.
Check the fuse first. If it is good, then I recommend going to the switch on the seat. There will be an orange wire with a red tracer. Check it for power.
Let me know what you find.
Sep 18, 2024 at 10:59 AM
KRISTENK16
It was the 40a fuse! Thank you so much. I have a bad habit of moving the seat completely back when I get out of the car, and of course that is when the fuse went bad and I could barely reach the pedal! Much appreciated.
Sep 19, 2024 at 6:31 AM
  • 110,251 POSTS
Thank you for the update and you are very welcome. I'm glad you found the issue. When I move customer cars around, it is nearly impossible to reach the pedals at times, but I don't want to change their settings. So, I usually just slide up like I was 10 years old. LOL
Take care of yourself and feel free to come back anytime in the future.
Sep 19, 2024 at 11:34 AM
