When driving it feels like engine loses power
272,198 MILES • 2.0L • 4 CYL • 2WD • MANUAL
DCOATES35
  • 45 POSTS
Hello Joe,
I'm sure you are tired of my car. Its been faithful to me so I put up with it. :)
Hopefully this will be the last question about something I can't figure out. So, when I'm driving my car and I'm going between 50-75 mph. I will be at a certain speed and steady for a while and my car feels likes it is losing power. It happens more often when I have my A/C on. I will be at 65 mph and the car feels like it is losing power but the speedometer never changes and then it will start working correctly. I had an electrical automotive place check it out and they said the grounds were good and they couldn't find anything wrong. I am going to have a second opinion to make sure.
Oct 21, 2019 at 5:31 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Also, welcome back. As far as the issue, does it only happen when the AC is on? I ask because if the AC compressor is cycling on and off and you feel it. Please keep in mind, if the AC is off but you have the defroster on, the AC compressor will still cycle. The defroster unit uses the AC to dehumidify the air going to the windshield.
PS: You are welcome to come back as often as you want. I don't want you to have more problems, but enjoy hearing from you. LOL
Oct 22, 2019 at 10:09 AM
DCOATES35
  • 45 POSTS
Thank you., it happens when the A/C is off as well. When your going fast and take your foot off the gas pedal and the speed drops. That is how it feels with my foot still on the pedal.
Oct 22, 2019 at 3:30 PM
  • 110,248 POSTS
Welcome back:
Interesting. Has anyone checked fuel pressure? Has the fuel filter ever been replaced? Based on the description, it sounds like it is starved for fuel. Also, it could even be related to a faulty catalytic converter. Do you ever hear any rattling under the vehicle when it's running?
Oct 23, 2019 at 1:44 PM
DCOATES35
  • 45 POSTS
The last time I had the fuel filter changed was earlier this year. I get it changed with my oil, radiator flush all that good stuff. There isn't any rattling anywhere either.
Oct 23, 2019 at 10:25 PM
  • 110,248 POSTS
Welcome back:
It will become a guessing game. If I had the car, I would first pull an oxygen sensor off before the catalytic converter. That will allow more air flow. Then drive to see if it changes.
It will set an engine code, but it can be reset.
Oct 24, 2019 at 11:21 AM
DCOATES35
  • 45 POSTS
I changed the one under the engine a few months ago. I am going to get the fuel filter changed and see what happens after that.
Oct 24, 2019 at 11:35 AM
  • 110,248 POSTS
Welcome back:
Let me know what you find. This is a tough one, especially because I can't drive it to feel what is happening. Anytime there is a power loss, I suspect a converter, fuel issue, and then something electrical.
I will watch for your reply.
Oct 24, 2019 at 1:50 PM
DCOATES35
  • 45 POSTS
Okay, i will let you know what i find. I will check the spark plugs as well.
Oct 24, 2019 at 2:43 PM
  • 110,248 POSTS
Welcome back:
Also, make sure things like the air filter are clean and not obstructed as well as check for vacuum leaks.
Oct 25, 2019 at 9:21 AM
DCOATES35
  • 45 POSTS
Good morning Joe,
The spark plugs were bad and I gt the fuel system flushed but it didn't solve the problem. My fuel pump is leaking, not sure if the would cause a power issue while driving. Once I'm able to get that check I will let you know what happens.
Nov 4, 2019 at 8:36 PM
  • 110,248 POSTS
Nice to hear from you Honestly, if you have a fuel leak that can absolutely cause power loss. Anytime fuel pressure is reduced, there will be some kind of issue.
Please be careful with this problem. Any type of fuel leak can be dangerous. Let me know approximately where you feel it's leaking from so I can try to help.
Take care and be safe.
Nov 5, 2019 at 2:51 AM
DCOATES35
  • 45 POSTS
I apologize, I didn't mean to say fuel. I meant power steer pump.
Nov 5, 2019 at 6:49 AM
  • 110,248 POSTS
Hi:
No problem. The power steering leak wouldn't cause a power loss. If you haven't already, check to confirm fuel pressure.
Nov 5, 2019 at 10:02 AM
DCOATES35
  • 45 POSTS
How do I check that? I had the fuel system flushed at Jiffy Lube.
Nov 6, 2019 at 10:15 AM
  • 110,248 POSTS
Here is a link that shows in general how pressure is checked:
Here are the specifications for your vehicle:
FUEL PRESSURE
Key On, Engine Off (KOEO) .................... 45-60 psi
Key On, Engine Running (KOER) .................... 42-57 psi
I realize most people don't own a fuel pressure gauge. However, most parts stores will lend/rent one to you.
Nov 6, 2019 at 10:53 AM
DCOATES35
  • 45 POSTS
I will check that out this weekend. Thank you
Nov 6, 2019 at 7:01 PM
  • 110,248 POSTS
Happy to help. Let me know what you find.
Nov 7, 2019 at 12:02 PM
DCOATES35
  • 45 POSTS
Good afternoon Joe,
Apologies for the long delay. I was working a lot and couldn't get a chance to work on my car. I had the power steering pump changed and the place where I had it done said that my alternator was going bad as well. I keep forgetting to get it checked at AutoZone or O'reillys. The last time it was changed was in 2012 so it may be the cause but I know it's time to change it.
Jan 13, 2020 at 3:46 AM
  • 110,248 POSTS
Great to hear from you. I hope you have a relaxing holiday.
That's interesting that they would test the alternator when replacing a power steering pump. Were there issues with the battery going low? Also, has the power issue been resolved?
Jan 13, 2020 at 11:40 AM
DCOATES35
  • 45 POSTS
It was okay, how were the holidays for you?
He didn't say he tested the alternator but I'm guessing he did since he said that. There were times where the car didn't want to start but the weather wasn't in its favor when that happened. The loss of power is still there, I am going to get it tested tomorrow for sure.
Jan 13, 2020 at 12:02 PM
  • 110,248 POSTS
Holidays were okay here too. LOL Let me know what is found when you have it checked. I'm interested in knowing.
Jan 13, 2020 at 1:07 PM
DCOATES35
  • 45 POSTS
That's awesome, I definitely will.
Jan 13, 2020 at 2:17 PM
  • 110,248 POSTS
Sounds great!!!
Jan 16, 2020 at 8:53 AM
DCOATES35
  • 45 POSTS
Hey Joe, turns out my alternator is bad. It's so expensive to change. I almost want to try fixing this one myself.
Jan 16, 2020 at 10:34 AM
  • 110,248 POSTS
Okay, the idea of replacing it yourself is very possible. It really isn't that hard. Take a look through this link. It explains how in general one is replaced.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Here are the directions specific to your vehicle for alternator replacement. The worst part of this job is you have to do part of it through the inner fender which requires you to remove the one wheel. Bit all in all, it's not that bad.
______________________________________________
1999 Mercury Cougar L4-122 2.0L DOHC VIN 3 SFI
Procedures
Vehicle Starting and Charging Charging System Alternator Service and Repair Procedures
PROCEDURES
REMOVAL
1. Disconnect the battery ground cable.
pic 1
2. Remove the intake air resonator.
1 Disconnect the air cleaner outlet tube.
2 Remove the bolts and nuts.
3 Remove the resonator.
- Disconnect the vacuum pipe underneath.
pic 2
3. Detach the coolant hose from the retaining clip.
pic 3
4. Disconnect the generator electrical connectors.
pic 4
5. Disconnect the ground cable.
6. Raise and support the vehicle.
7. Remove the right front wheel.
pic 5
8. Remove the splash shields.
1 Remove the bolts.
2 Remove the splash shields.
9. Remove the accessory drive belt.
pic 6
10. Remove the generator lower bolt.
11. Lower the vehicle.
pic 7
12. Remove the generator upper bolt.
pic 8
13. Remove the generator.
CAUTION: There is a very limited amount of space in which to remove the generator. Do not overstress or damage any hoses or cables.
pic 9
pic 10
INSTALLATION
1. To install, reverse the removal procedure.
Let me know of this helps. If you have trouble, I can help.
Jan 17, 2020 at 12:17 PM
DCOATES35
  • 45 POSTS
I'm not sure if I'm missing a step or my car is different. I removed the air intake, the alternator is right under it, somewhat. I removed the belt and the upper bolt, which was easy to take out. When I got the lower bolt loosened it only came out half way. The tire wall is blocking it from coming out. I need to raise or lower the engine to do that but not sure how. I can't seem to find anything I need online for completing that task.
Jan 18, 2020 at 4:11 AM
  • 110,248 POSTS
Is there a black bracket mounted to the lower part of the alternator?
Jan 18, 2020 at 9:11 AM
DCOATES35
  • 45 POSTS
I'm not sure but I will check in the morning, I was going to jack the motor up and try it that way. I will check before I do any thing else.
Jan 18, 2020 at 9:24 AM
  • 110,248 POSTS
Let me know. If there is, you may need to remove it. The mount can be seen from under the vehicle. Nothing is ever easy. LOL If you lift the engine, make sure you place the jack in a spot that won't damage anything. I've seen people lift the engine by the oil pan and it wasn't a good thing. LOL
Please let me know if I can help.
Jan 18, 2020 at 9:42 AM
DCOATES35
  • 45 POSTS
Okay, I'm glad you mentioned that. I was looking at areas to use to lift it.
Jan 18, 2020 at 7:00 PM
  • 110,248 POSTS
Not a problem. Also, keep in mind that it is still mounted on the car, so it will only go so far before it starts lifting the vehicle. Please be careful.
Jan 19, 2020 at 5:17 AM
DCOATES35
  • 45 POSTS
Thank you, I was able to change it out. The problem with the voltage dropping is no more. I guess it was caused by the alternator the whole time.
Jan 19, 2020 at 10:24 AM
  • 110,248 POSTS
You are very welcome. What enabled you to get that bolt out from the alternator? Also, I'm glad it's fixed and working right for you.
Take care and feel free to come back any time you have questions.
Jan 19, 2020 at 12:17 PM
DCOATES35
  • 45 POSTS
Well apparently the housing for the bolt is a half moon. The other half is on the alternator and the bolt holds them together. I didn't realize that until it came out. I didn't have to raise or lower the engine. I'm sure I will be back. Have you heard of anyone using CLR to clean out the heater core. I can make that another question if you need me to.
Jan 20, 2020 at 4:11 AM
  • 110,248 POSTS
Yes, it is a very common product and works really well. Just make sure to follow the manufacturer's directions. As far a starting a new link, I hate to ask, but I need you to. I will watch for it. We try to keep the threads focused on the same topic.
But, I have heard of it, it's commonly used, and works well.
Take care of yourself.
Jan 20, 2020 at 11:43 AM
DCOATES35
  • 45 POSTS
Okay, that's no problem. I will start a new one.
Jan 20, 2020 at 12:39 PM
  • 110,248 POSTS
Jan 21, 2020 at 8:46 AM
