Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
Ion
Interior
Power Outlet
Power outlets
2004 SATURN ION
111,847 MILES • 2.2L • 3 CYL • 2WD • AUTOMATIC
BRADEN MCCANN
MEMBER
My front power outlet does not work and the back one works perfectly. it occurred after using an electric air pump using front outlet.
Jul 19, 2017 at 11:40 AM
SATURNTECH9
Experienced Mechanic
You blew the fuse by using the pump that was too much drama for the fuse.
Jul 19, 2017 at 12:43 PM
SATURNTECH9
The fuse labeled lighter is the fuse you want to replace, it is a 15 amp mini fuse.
Images (Click to enlarge)
Jul 19, 2017 at 12:47 PM
BRADEN MCCANN
MEMBER
Thanks so much it worked perfectly!
Jul 20, 2017 at 10:47 AM
SATURNTECH9
Your welcome glad it went well please tell all your friends about us.
Jul 20, 2017 at 12:45 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
