I parked my car for approximately a year. Put in new battery. Car turns over and starts, but none of power options work windows, locks, alarm, etc.
Nov 28, 2016 at 3:35 AM
DOCHAGERTY
✓Experienced Mechanic
Have you checked the fuses yet?
Nov 28, 2016 at 7:55 AM
LOUISCESARINI
MEMBER
No. I didn't know you could blow a fuse just by hooking up a new battery. But I will do that next and let you know.
Thanks
Nov 29, 2016 at 9:32 AM
LOUISCESARINI
MEMBER
The fuses are all good. at first I said the car would start, now it turns over but won't start and I still have no alarm, power windows, locks, seats, etc. There must be some way to reset the system.
Nov 30, 2016 at 1:34 AM
You didn't happen to hook up the battery backwards for a second did you? If not there must be a main relay that got burnt up, there is a main power supply that is not working. I tried looking up the wiring diagram but Mitchell1 doesn't seem to have the info we need. Use a test light and start probing around.
Please let us know happens so it will help others.
