When accelerating or under a small load like going up a slight incline even, it completely loses power and you can hear it 'gasp' for air, then it surges with power for a second, then gasps again, then surges with power, then gasps etc...
I have tried replacing the Mass Airflow unit and the foul air breather tube that goes to rear of engine from the air inlet.
When I put a vacuum gauge to the PCV orifice on the front of the engine, I thought it would be sucking air into the engine, but it is pulling it in the other direction (see video attached) - I'm not sure if that is normal or not, maybe the video will provide some clues or I can make another and test something if you need me to.
Aug 7, 2021 at 3:06 AM
