Tachometer and speedometer quit working and loss of power?
180,000 MILES
KCMOREHOUSE
Starts up fine, but no power. Also, the blower motor will work with acc on but when you start the engine no more blower.
Feb 28, 2023 at 2:03 AM
  • 110,248 POSTS
Did the blower motor issue start at the same time as the speedo and tach issue? Let me know that. Also, I need you to scan the computer to determine if there are any useful diagnostic trouble codes.
This vehicle has an OBD1 system that doesn't require a scan tool for retrieving codes. All you need is a short jumper wire or even a paper clip will work.
Follow the directions in this link and let me know what you find:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know if there are any other electrical concerns.
Feb 28, 2023 at 12:30 PM
