Starts up fine, but no power. Also, the blower motor will work with acc on but when you start the engine no more blower.
Feb 28, 2023 at 2:03 AM
✓Experienced Mechanic
Did the blower motor issue start at the same time as the speedo and tach issue? Let me know that. Also, I need you to scan the computer to determine if there are any useful diagnostic trouble codes.
This vehicle has an OBD1 system that doesn't require a scan tool for retrieving codes. All you need is a short jumper wire or even a paper clip will work.
Follow the directions in this link and let me know what you find:
