power loss
1999 DAEWOO LANOS
60,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
MANNYANTHONY
start ok on high but stalled on idle
Feb 29, 2016 at 1:07 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner. if it continues scan for codes and check fuel pressure with a gauge auto parts rent it
Mar 16, 2016 at 9:38 AM
MANNYANTHONY
thanks for the answer. your answer is right. I got a new pump with out checking the pressure and got it fix. wasted of money because the problem was just a clogged pump filter. now I know better. oh well, now I have a spare pump. I just want to post it so everybody find out about the pump filter.
Mar 16, 2016 at 4:41 PM
  • 55,109 POSTS
Thanks for getting back to us
Mar 19, 2016 at 12:17 PM
