Power loss
300,000 MILES • 2.0L • 4 CYL • TURBO • AUTOMATIC
JOHNDSLV95
The car loses power and does not rev more than 2,000 rpm's. what could be?
Dec 14, 2018 at 4:09 AM
DANNY L
  • 5,648 POSTS
Hello,I'm Danny,
Have you noticed a rotten egg odor coming from the exhaust?It could be your catalytic converter(s) are plugged causing your bad gas mileage and loss of power.By any change have you noticed if the check engine light is as well? If so there might be a fault code stored in your cars computer.If you can access those codes and get back to us with the code numbers we can help properly diagnose. I have attached a few tutorials for you t view showing what's involved.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Hope this helps and thanks for using 2CarPros.
Danny-
Dec 16, 2018 at 3:52 PM
