Power issues and coolant leak
2008 HONDA CIVIC
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
MSEIBER1976
Hi, i have the car listed above that over the past three months have had a few issues. My check engine light comes and goes on but it solid on usually. On occasion, it flashes. I can usually restart the car and it just stays on or goes off. I have taken to AutoZone and it says code of cylinder two misfire. I have change the plugs and have had someone look at the wires and the coils and are good. Recently, I have had coolant issues. Two months ago, it overheated and the reserve was low or empty. It was refilled but no leak was detected by the mechanic. No fluid is found on the ground. today, I check it after a defrost issue and it is dry again. And not any fluid on the ground. So not sure where it is going. I also have noticed a drop in gas mileage. maybe twenty miles a tank. And also have an rpm problem that comes and goes. usually around 45 or so, I feel the car almost lose power, then bam it takes off. I have watched the rpm's and they will go from 2,100 to 1,500 then up to 2,800 before settling. not sure why that is going on. Are all the issues the same issue?
Dec 11, 2018 at 12:56 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It sounds like you might be having a cylinder head gasket issue. If the head gasket is leaking that would allow the engine coolant to be burned while engine is running. That would explain the bad mileage, misfire, and coolant disappearing with no leaks on the ground/visible. Another indicator is having water in the oil and oil in the radiator. I have attached a tutorial for you to view.
Hope this helps and thanks for using 2CarPros.
Danny-
Jan 28, 2021 at 1:28 AM
