As I accelerate the car produces a very low amount of power
54,000 MILES • 2.0L • TURBO • 2WD • AUTOMATIC
DBATCH1992
It seemed to drive fine with no dash lights or errors coming up. When stationary if I rev the engine it seems to barely rev either.
Feb 19, 2020 at 10:27 PM
JOETECHPRO
  • 705 POSTS
Hey DBATCH1992,
It sounds like you could have a restriction in the intake or exhaust or a boost leak.
Have you checked the engine air filter?
Is there any reason you would have damaged the exhaust system prior to this fault?
Have you checked for engine management fault codes?
Guide in the link below:
I do not have the specifics for your vehicle here but if you can provide us with a list of fault codes we can try and advise you on potential causes.
I would advise checking the connections of the air intake pipes are tight and you don't have any damage to any of the boost pipes.
A sign of a boost leak is oil residue around the intake piping.
Also check through the front bumper for signs of damage to the inter-cooler, again a leak would be seen generally by oil being present.
Let us know what you find.
Regards, Joe
Feb 20, 2020 at 4:55 AM
