Windows and heater are not working after replacing voltage regulator
210,000 MILES • 4 CYL • 2WD
TRAVIS HILL
My alternator had a bad voltage regulator. I changed it. Everything seems fine now except my windows won't work now and neither will my heater.
Dec 2, 2019 at 11:28 AM
  • 110,248 POSTS
First, have you checked fuses? That is where I would start. Pic 1 shows the power window fuses. Check them. When you say the heater isn't working, do you mean the blower motor doesn't turn on? If that is the case, you need to check for power to the blower motor relay mounted near the motor itself. There is a white wire that goes to it which should have power. Power is supplied via what is called a fusible link. It isn't a fuse, but functions as one. It looks like a regular wire, but will fail if too much power goes through it.
See pic 2 for fusible link. Pic 3 shows the blower motor relay. It is under the dash near the blower motor. I circled the relay to help.
Here are a few links you may find helpful:
If there is power to the relay, here is a link that shows how to check a relay:
Let me know what you find or if you have other questions
Dec 2, 2019 at 12:31 PM
TRAVIS HILL
Window fuses are good. Haven't checked the motor relay.
Dec 2, 2019 at 1:01 PM
  • 110,248 POSTS
If the fuses are good and they have power, the next step is to check for power at the window switch. Tell me, when the regulator was bad, was it over charging the system?
Dec 2, 2019 at 1:19 PM
