Both cigarette lighter power outlets, when used, blow the 15a PWR outlet fuse.
Replacing the fuse initially worked with a rechargeable flashlight. When I plugged in my inverter (which always used to work) green power light goes on then fades and goes off and 15 amp power outlet fuse is blown.
Same thing happened in my 2012 Rav4 when I plugged the same inverter in. So I figured it was a short in the inverter causing the problem.
But then, I replaced the fuse again (van), plugged in the flashlight and my flashlight will now not charge in the car or a wall outlet (red light indicating something is wrong on flashlight). Then plugged in the inverter and blew the 15 amp fuse again in the van.
So I am thinking a short in the inverter shorted out and messed up the electrical in the van since after replacing the fuse the flashlight also got messed up.
Perhaps replacing the relay in the van will do the trick, and throw away the inverter.
Does anyone have a relay diagram and which relay I should replace?
I also had just had my battery replaced in the van before all this started. But the inverter worked for several hours with the new battery, and the next time I plugged it in, it blew fuses in both vehicles.
Jan 10, 2018 at 4:02 AM
