Power down
137,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
HERMANF1961
  • 8 POSTS
While driving the truck will power down shutting it off and reset will run fine again
Feb 10, 2016 at 9:28 AM
please define power down????
Feb 10, 2016 at 10:20 AM
HERMANF1961
  • 8 POSTS
Upon hitting a hill sometimes flat surface while accelerating the call will not move and you still running it will idle shutting off the ignition and restarting the call will run normal for a while
Feb 10, 2016 at 10:42 AM
ok, do you have the check engine light on??
Feb 11, 2016 at 2:34 AM
HERMANF1961
  • 8 POSTS
The light doesn't always come on sometimes no code
Feb 11, 2016 at 6:12 AM
it sounds like the fly by wire system is not working. it is the system that controls your accelerator pedal. does this make sense
Feb 11, 2016 at 6:23 AM
HERMANF1961
  • 8 POSTS
I can understand what you're saying but I don't know what you mean
Feb 11, 2016 at 6:25 AM
is it where the engine is running but you cannot accelerate???
Feb 11, 2016 at 6:33 AM
HERMANF1961
  • 8 POSTS
Yes you don't accelerate and I'm going nowhere when you shut it off turn it back on it works fine for a while
Feb 11, 2016 at 6:37 AM
ok that sounds like the system. the most common failure is the throttle position sensor on the side of the throttle body. check it for damaged connector and pins
Feb 11, 2016 at 6:41 AM
HERMANF1961
  • 8 POSTS
Replace that twice already same problem still exists
Feb 11, 2016 at 6:46 AM
ok what else have you done so we dont cover the same real estate
Feb 11, 2016 at 6:49 AM
HERMANF1961
  • 8 POSTS
Mass air flow sensor fuel filter air temp sensor spark plugs cap rotor wires PCV valve air filter
Feb 11, 2016 at 6:53 AM
none of that has anything to do with the issue
there is a pedal sensor that has the control module on it that is the other half of the system. have you had that checked???
Feb 11, 2016 at 6:58 AM
HERMANF1961
  • 8 POSTS
No I haven't I will have that checked out
Feb 11, 2016 at 7:00 AM
ok
Feb 11, 2016 at 7:05 AM
