Power seat switch removal
61,000 MILES
CARL BARRIO
When replacing power seat switch under seat-does old switch just pry out?
Sep 3, 2018 at 11:55 AM
  • 110,248 POSTS
Here are the directions specific to your vehicle for switch replacement. All attached pictures correlate with these directions.
____________________________________________
SEAT SWITCH REPLACEMENT - POWER
Seat Switch Replacement - Power
Removal Procedure
1. Remove the outer trim panel from the front seat cushion. Refer to Seat Cushion Outer Trim Panel Replacement - Front Seat (See: Seat Cushion > Removal and Replacement > Seat Cushion Outer Trim Panel Replacement - Front Seat) .
2. Use a small flat-bladed tool to release the retainers which hold the power seat switch to the outer trim panel.
3. Remove the power seat switch from the outer trim panel.
4. Remove the power seat switch harness from the front seat support.
5. Disconnect the electrical connector from the power seat switch.
6. Remove the power seat switch.
Installation Procedure
1. Connect the electrical connector to the power seat switch.
2. Install the power seat switch to the outer trim panel, pressing the switch into place until fully seated.
Important: The power front seat switch harness must be in the proper position for the proper installation of the outer seat cushion trim panel.
3. Connect the power seat switch harness to the front seat support.
4. Install the outer trim panel to the front seat cushion. Refer to Seat Cushion Outer Trim Panel Replacement - Front Seat (See: Seat Cushion > Removal and Replacement > Seat Cushion Outer Trim Panel Replacement - Front Seat) .
Let me know if this helps.
Sep 4, 2018 at 10:58 AM
CARL BARRIO
Works like a charm. Thank you very much.
Sep 5, 2018 at 5:30 AM
  • 110,248 POSTS
Hi Carl:
Glad to help. Let me know if you have questions in the future.
Sep 5, 2018 at 11:27 AM
CARL BARRIO
Thanks for help, instructions clear good job.
Sep 7, 2018 at 4:17 AM
  • 110,248 POSTS
No problem. Take care and let us know if you have questions in the future.
Sep 7, 2018 at 11:11 AM
