Images (Click to enlarge)
May 11, 2021 at 2:58 AM
PACIFICISLANDER
MEMBER
Will the ignition coil spark by itself when the (4) wire connector is disconnected from the distributor knowing the fact it has crank/cam sensor in the distributor?
May 15, 2021 at 3:55 PM
✓Experienced Mechanic
Yes, it is in the distributor.
May 18, 2021 at 2:57 AM
PACIFICISLANDER
MEMBER
To my understanding the coil will not fire if the 4 wire connector from the distributor is disconnected.
