Then check for the same power to the fuse block under the hood. Make sure there is power to the fuses.
Make sure the battery cables are clean and tight.
Jul 21, 2018 at 8:20 AM
TYLER CORRIHER
MEMBER
All the power is good, but is my ASD relay supposed to have two different volts to it?
Jul 21, 2018 at 8:22 AM
✓Experienced Mechanic
That is for the engine controls, yes. But that does not explain why you do not have dash or anything else. You stated it is completely out. The ASD relay does not control everything.
Jul 21, 2018 at 8:26 AM
TYLER CORRIHER
MEMBER
Oh okay, well either way I do not have that, but I do have head lights and turn and brake.
Jul 21, 2018 at 8:27 AM
Okay, that is all new information you did not give us.
When you turn on the ignition, does the check engine light come on?
Yes, you have battery power and ignition power to the relay. The ECM grounds the relay to send power off to the ignition system.
Image (Click to enlarge)
Jul 21, 2018 at 8:35 AM
TYLER CORRIHER
MEMBER
No, the check engine does not come on nothing does not, but I can turn my head lights on I do not have turn sorry.
Jul 21, 2018 at 8:37 AM
At this point, I would suspect an ignition switch. You need to check for power to the switch and see if there is any coming out of it.
Jul 21, 2018 at 8:41 AM
TYLER CORRIHER
MEMBER
Is that the black box under the dash?
Jul 21, 2018 at 8:42 AM
It is at the bottom of the column. Picture and pin out attached.
Images (Click to enlarge)
Jul 21, 2018 at 8:48 AM
TYLER CORRIHER
MEMBER
Would this be it?
Jul 21, 2018 at 8:53 AM
That piece is the high beam switch. That is bolted to the ignition switch. If you remove the high beam switch you will see the ignition switch.
Jul 21, 2018 at 9:02 AM
TYLER CORRIHER
MEMBER
So I have one current to the plug the parking switch but nothing else.
Jul 21, 2018 at 9:12 AM
Plug? What plug? Parking switch?
I thought we were talking about the ignition switch?
Jul 21, 2018 at 10:02 AM
TYLER CORRIHER
MEMBER
We are, the plug on the ignition switch according to the diagram is the parking switch that the only power is that.
Jul 21, 2018 at 10:05 AM
That picture shows the high beam switch and the ignition switch.
Jul 21, 2018 at 10:08 AM
TYLER CORRIHER
MEMBER
Oh okay, so how do I measure for voltage on the ignition switch?
You use a voltmeter. I sent you the diagram for the pins and color of the wires. Verify powers to the switch and then check for voltage coming out of the switch with the key on.
Jul 21, 2018 at 10:15 AM
TYLER CORRIHER
MEMBER
There was no power coming out. Thank you for your time.
