Possible transmission issue
162,043 MILES • 5.7L • V8 • 2WD • AUTOMATIC
TMCINTOSH11
  • 176 POSTS
Hi, I have the car listed above with a V8 hemi and I noticed that around 40 mph it acts like it kinda struggles to rev up or accelerate, it does speed up but it not exactly smoothly. it kinda shakes a little and it revs up and down slightly. I checked the trouble codes at the dealership and nothing but a seat belt sensor came up. I didn't know if it was because of the ESP (electronic stability program), everything with the engine is fine because at first I thought it was a throttle issue, it takes off just fine at stops and seems to shift okay. it's just at 40 or above it acts like it doesn't want to give itself power to go faster. I apologize if this is a little hard to follow it's kind of hard to explain. any ideas would be great. thanks guys!
Feb 6, 2020 at 11:02 AM
CARADIODOC
  • 34,414 POSTS
You're describing a torque converter shudder caused by using the wrong type of transmission fluid. To verify this, when the shudder occurs, hold the accelerator pedal and road speed steady, then lightly tap the brake pedal with your left foot. The shudder will stop, then come back in about two or three seconds.
Feb 6, 2020 at 11:30 AM
TMCINTOSH11
  • 176 POSTS
I'll try that today when I drive it. I've had the car about a week, one of the trouble codes was for wrong type of engine oil so I'm guessing when the guy I bought it from changed the oil and he probably changed the transmission fluid too. Mostly likely put the wrong fluid in it too. so if I can verify that this is indeed the problem how could I fix it? At 162,000 miles I'm kinda leery about changing the transmission fluid but if you think it wouldn't hurt it I can try that.
Feb 6, 2020 at 6:25 PM
CARADIODOC
  • 34,414 POSTS
My 1994 Grand Voyager daily driver has had this shudder real bad for the three years I've been driving it. The previous owner severely neglected regular maintenance on the cooling system and transmission, but she did have it in three times for a very intermittent failure to up-shift. Turned out to be caused by nothing related to the transmission, but I'm sure at some point the fluid and filter got replaced as part of the attempt to solve that problem.
When I have to stick to around 35 - 40 mph, I press the "Overdrive off" switch to keep engine speed up a little. At the higher RPM, the torque converter locks up solidly so that shudder doesn't occur. At the lower engine speed, the clutch is in partial lock-up to ease the engagement for comfort. With the missing additives in the fluid, that controlled slippage causes the clutch to lock too aggressively, then get torn loose by engine torque, then it tries to lock up again. This repeated action is what you feel as the shudder.
Another clue is this lock-up never occurs until engine coolant reaches a certain temperature. On really cold winter days I can drive up to six miles before the clutch locks up. On mild summer days I get about a mile before that occurs.
I'm not sold yet on the need to flush transmissions. If that is done in an attempt to solve a problem, that problem is usually caused by something mechanical, and flushing the system isn't going to fix that. If the flush is done for maintenance, there is nothing that's going to be accomplished that a regular drain and fill won't do. The drain and fill replaces half of the fluid which is enough to replenish the additives.
If you can put up with the shudder, wait until the next scheduled service is needed, then have the fluid and filter replaced. If this is too irritating, have that service done now, but be sure to mention the shudder and the need to use the right fluid as the reason you want this done.
Feb 7, 2020 at 4:00 AM
TMCINTOSH11
  • 176 POSTS
Thanks so much, I got an appointment at the dealership Monday so I'll ask them when it might be a good time to do that, I tried what you said with the brakes and I couldn't notice a difference but maybe I did it wrong, it's not terrible and I can live with it, sometimes the car will shake if I pressure the throttle enough, it's not like I'm gonna be racing in it, I'm not even sure how to check the trans fluid, I didn't see the stick anywhere under the hood, but it shifts and takes off really well, it's just when it gets to 35 or 40 when I start having problems, it also does it whether it's hot or cold, thanks for getting back to me!
Feb 8, 2020 at 11:08 AM
JOETECHPRO
  • 705 POSTS
Hey TMCINTOSH11,
There looks like there is a TSB for water contamination of the A/T fluid on these vehicles that will cause the torque converter lock up shudder previously described. TSB attached below.
The water leaks in around the transmission oil fill tube.
You would need a transmission flush and replacement seals if this TSB is applicable.
You may want to raise this with the dealership too.
Hope this helps, please keep us updated with your progress.
Regards, Joe
Feb 9, 2020 at 3:04 PM
TMCINTOSH11
  • 176 POSTS
Thanks for the info. I found the transmission fill tube under the hood and it looks like it has a cap on it with "for dealership use only" or something on it so I didn't mess with it. what mainly can I actually do at this point? Could I just change the fluid myself (which I don't think is a good idea) and maybe add Lucas transmission fix or a friction modifier? Thanks for getting back to me!
Feb 10, 2020 at 3:39 AM
CARADIODOC
  • 34,414 POSTS
Don't use additives in a transmission. The correct transmission fluid already has the additives determined to be needed by the people who designed the transmission. When you start mixing different products, they can have additives that fight each other. This is equally important with engine oil. You can run into a seal conditioner in one brand of oil that is not compatible with a detergent in another brand. There's also dispersants, corrosion inhibitors, viscosity index improvers, and anti-foaming agents that all have to work together.
Feb 10, 2020 at 7:03 AM
TMCINTOSH11
  • 176 POSTS
Good to know thank you! So should I try doing a transmission fluid change myself or is it best to leave it? Thanks for your help!
Feb 10, 2020 at 7:18 AM
CARADIODOC
  • 34,414 POSTS
I left the dealership after 1999. Since then, a lot of manufacturers have gone to designs that prevent you from doing your own service on their transmissions. One can only wonder what that accomplished or how it benefits the car owner.
I was going to post the procedure for checking the fluid level and for performing the seal repair, but those require very specialized tools and equipment that only the dealer has. I prefer to do all my own work on my vehicles, but this is one time when it probably is beneficial to visit the dealer. In the long run you will be better off. The fluid level has to be calculated from reading its temperature with a scanner, the level on a special probe inserted through the tube, then finding a point on a graph.
Here's the service bulletin JOETECHPRO referred to.
Feb 10, 2020 at 7:55 AM
TMCINTOSH11
  • 176 POSTS
Okay, I been driving it getting a better feel of how it's acting and I know what you mean now by tapping the brakes so that the engine becomes free to throttle for acceleration, it seems to do this half the time, like if I'm doing 40 and I press the brake some it doesn't always break the engine free to accelerate, sometimes it does though, and sometimes it will slowly rev up to accelerate more, kinda like it's fighting against the transmission, I just try not to push it, I was doing 60 in it the other day and it almost cleared up the problem altogether, it's kinda hard to explain but it's just that it doesn't want to disengage to accelerate, maybe it's the overdrive gear sticking? Thanks for all your help.
Mar 1, 2020 at 9:07 PM
CARADIODOC
  • 34,414 POSTS
You won't get the torque converter shudder at 60 mph. This only happens at partial lock-up which occurs around 30 - 40 mph. At lower speeds it doesn't try to lock up at all. At higher speeds it locks solidly unless you hit near wide-open-throttle. It's just in that small range of partial lock-up that is does so too aggressively, then engine torque breaks it free, and this repeats very quickly. Partial lock-up is supposed to come in gradually so you don't feel it as a clunk or thump. That's strictly for comfort. To engage gradually requires the right combination of additives to let the clutch plates slip and grab smoothly.
Mar 2, 2020 at 11:08 AM
