Possible oil leak around pump gasket?
216,667 MILES • 3.5L • V6 • 2WD • AUTOMATIC
ETERNALARIANNE
  • 240 POSTS
I had the van in the shop for a valve adjustment and they did the full visual inspection. They said I had a leak around the oil pump gasket and showed a video. To me it looks like "road grime" all over the bottom of the pan and sides of the motor. They said this type of leak can get into the timing belt and cause it to fail prematurely. I just had the timing belt done around 15K miles ago and they didn't mention a leak, so this must be a newly formed leak? I also haven't noticed any drip in my driveway and the oil level is always good.
I was going to spray some degreaser all of over the bottom of the motor and try some of that AT-205 (that I've heard many mechanics recommend for Hondas with any kind of leak) and see if it is indeed a leak. I just can't afford $1700 to have it fixed right now I just dumped $$$ on the valve adjustment.
If there is indeed a leak there that just formed recently, how worried should I be, especially with trying the AT-205 that might fix it?
Apr 10, 2026 at 11:07 PM
  • 55,691 POSTS
You have the right idea, If you don't see any leak on the ground I would do the cleaning and keep an eye on it, if the problem is just a "seep" you should be okay to let it go. You may want to try Lucas engine stop leak because it can help swell the seals and get them to stop leaking. Please upload a short video in your response of the problem, so I can see what's going on if needed. Ken
Apr 12, 2026 at 1:43 AM
ETERNALARIANNE
  • 240 POSTS
I trimmed the inspection video to just the part where he's talking about the oil pump gasket leak
Apr 12, 2026 at 2:03 AM
  • 55,691 POSTS
Thanks for the video. Yep that is one the line for a oil leak bad enough for a repair. This will be your call to let it go are make the repairs.
Apr 12, 2026 at 2:55 AM
ETERNALARIANNE
  • 240 POSTS
I know it might be difficult to judge, but let's say it is leaking onto the timing belt. Since the belt was just changed around 15K miles ago, would it last until the next timing belt change at 300K? The reason I'm asking is I think they replace the timing belt as part of the repair, and I don't want to "waste" the new timing belt I just had put on by replacing it yet again...
Apr 12, 2026 at 11:19 PM
  • 55,691 POSTS
Yep, if the engine oil is getting onto the timing belt that is a problem and the seal will need to be replaced. Can you remove the cover to see if that is the case?
Apr 13, 2026 at 1:57 AM
ETERNALARIANNE
  • 240 POSTS
Well hopefully I can squeeze some time out of it since I just had the timing belt done and it's like $1700 for the fix
Apr 13, 2026 at 1:58 AM
  • 55,691 POSTS
Yep, chances are you are okay since the oil is not dripping on the ground.
Apr 14, 2026 at 12:34 AM
ETERNALARIANNE
  • 240 POSTS
I was looking through the maintenance records and at some point they said the "rear main seal" was leaking but they never fixed it and it was never mentioned again in the records. Could this be where the leak is actually coming from? Also, I have started to see some kind of fluid on the ground now but the oil and transmission levels are fine...
May 2, 2026 at 6:58 AM
  • 55,691 POSTS
On a 15 year old car an oil "seep" is normal. how big is the puddle, can you upload an image?
May 2, 2026 at 10:09 AM
ETERNALARIANNE
  • 240 POSTS
Attached an image of the fluid spot on the ground. Again, oil and transmission levels are good. Brake fluid and PS are good. Coolant was at the MIN line but not empty
May 2, 2026 at 10:30 AM
  • 55,691 POSTS
Yep, that is too much. It does look like it can be the rear main seal by the position of the leak. We need to raise the front of the car for inspection. Thanks for the image, it helps.
May 2, 2026 at 10:57 AM
ETERNALARIANNE
  • 240 POSTS
So based on the video I posted earlier and this, is it possible it's the rear main seal and not the oil pump gasket?
May 2, 2026 at 10:59 AM
  • 55,691 POSTS
Oil can travel for sure but from what I see I would think the rear main seal is leaking, we need to get the car in the air for inspection underneath.
May 3, 2026 at 2:29 PM
ETERNALARIANNE
  • 240 POSTS
I put some cardboard down under the car and parked over it for a few hours. I got about a tennis ball size spot of fluid that is definitely oil based on the look and smell. And it's directly in the middle of the engine so either the rear main seal or oil pan for sure.
I guess I have two leaks but the oil pump gasket isn't as bad...
May 4, 2026 at 12:00 PM
  • 55,691 POSTS
Yep, that is what it looks like, if the oil leak showed up all at once it is most likely the rear main seal popped out which is common.
May 5, 2026 at 7:27 AM
ETERNALARIANNE
  • 240 POSTS
Ok so while replacing the AC compressor we got a good look underneath. Not seeing any oil leak around the oil pump gasket, or even the rear main seal. The oil leak is coming from the top driver side of the motor somewhere. They did mention the cam-end seals were seeping but this is more than a seep lol
I also just had valves adjusted I wonder if the valve cover is leaking?
Jun 25, 2026 at 12:34 PM
  • 55,691 POSTS
Yep, that is what I was going to suggest. I would use a mirror on a stick to have a look at the bottom edge. Use a flashlight as well. If you can please upload a short video in your response of the problem, so I can see what's going on.
Jun 25, 2026 at 2:59 PM
ETERNALARIANNE
  • 240 POSTS
I couldn't get a good video but I attached the inspection video from the dealer. The oil is definitely leaking from the same spot the guy was pointing to for the Cam-end seal on the backside of the motor. I'm guessing the seep has gotten worse lol
Jun 25, 2026 at 4:24 PM
  • 55,691 POSTS
I looked at the leak it does not look too bad, can we get a video of the leak from under the engine? It might be the oil pan seal or rear main.
Jun 25, 2026 at 5:33 PM
ETERNALARIANNE
  • 240 POSTS
That one will take a bit since it's back on the ground now after replacing the AC compressor. But the leak was definitely running down from above it doesn't look like it's coming from the oil pan or rear main seal. I'll see if I can get a pic/video next time we have it lifted
Jun 25, 2026 at 5:38 PM
  • 55,691 POSTS
Sounds good, can I ask if the see the leak on the ground and if so how much?
Jun 25, 2026 at 5:40 PM
ETERNALARIANNE
  • 240 POSTS
Yeah it's visible on the ground there should be a pic up above somewhere
Jun 25, 2026 at 5:41 PM
  • 55,691 POSTS
Sorry, yep that is a leak alright. It looks more like a rear main seal, is the cam plugs what the Honda tech said? did he look under the car?
Jun 26, 2026 at 10:54 AM
ETERNALARIANNE
  • 240 POSTS
Yeah they said both cam end plugs were "seeping", as well the oil pump gasket was leaking. But I don't see anything around the oil pump or pan besides road grime. The only place I see anything substantial is running down from the back driver side of the motor...
I ordered a boroscope I'm going to run it back down behind the motor and take a look around, as well as around the oil pump area. I'll report back what I find
Jun 26, 2026 at 10:59 AM
  • 55,691 POSTS
Yep, that leak should be obvious and not a "seep"
Jun 26, 2026 at 11:06 AM
ETERNALARIANNE
  • 240 POSTS
Ok I managed to get pics of around the cam-end plug on the back driver side. It definitely is leaking and not just a "seep" at least to me. I didn't really see any leaks anywhere else, all road grime.
Jun 27, 2026 at 4:21 PM
  • 55,691 POSTS
Yep, that is not a seep, that is a leak it looks like you found the problem, I would replace the O right seals and then clean the engine to watch for any other leaks. Let me know how it goes.
Jun 28, 2026 at 9:55 AM
