Will not start after overheating?
2008 DODGE CALIBER
19,889 MILES
INDYALEWIS22
hello, i was wondering what it would mean if my brother replaced my starter and battery, but the car still won't start. It stopped on me due to overheating i guess and it was smoking. he said oil leaked into my engine but I'm still not sure what to do.
Feb 1, 2024 at 11:44 PM
BORIS K
  • 836 POSTS
The best check to do is to conduct a compression test.
This could then point to a possible mechanical issue with the engine
Some interesting reading:
https://www.2carpros.com/articles/symptoms-of-low-compression
and
https://www.2carpros.com/articles/the-reasons-for-low-compression
and
Video on compression test:
https://youtu.be/J3j85hg0d-4?si=8DyE55nXWIb90LYR
Expect to see 150-160Psi on each cylinder for good compression readings.
Cheers, Boris
Feb 2, 2024 at 1:09 AM
