Recently purchased the vehicle listed above was informed upon purchasing then the distributor was bad according to a reputable shop. however, I do not believe that's the case. plans to the fact when I put the key in and try to turn it over the volt gauge goes backwards and it makes the sound as if you had a bad battery. however, the battery is good but starter does not engage. I do not hear the fuel pump kicking on and I also hear what appears to be a clicking noise by the left side of the firewall. any thoughts or questions or knowledge of where to start? thank you
Jul 31, 2019 at 5:11 AM
