Possible ECU?
120,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BONGO MINDANAO
Hi, when I start my Mazda Bongo Friendee cold in the morning this is what happens:
1. All 3 fans running. Fan2, Fan3 and Scavenger Fan.
2. Glow plug Relay doesn't operate.
3. Aircon compressor doesn't start.
4. Automatic gearbox in limp mode doesn't change to fourth gear.
What I have done is:
1. Service engine, oil and filters.
2. Oil change Automatic Transmission.
3. New Engine Coolant Temperature Censor. ECT.
4. Engine Temp censor to Dashboard is 100%.
5. Aircon gas is 100%.
6 If you pull Fan fuses next to Mains and Add Fan fuse, they stop operating.
Jul 22, 2022 at 9:16 PM
  • 55,710 POSTS
We need to do a CAN scan for codes to see what's going on, also has the car had any water damage? You can get a CAN scanner from Amazon for about $30.00. here is a video to show you how.
https://youtu.be/u-4syLc-ifQ
Here is a scanner link:
https://amzn.to/3o41KcZ
Let's remove the electrical connector from the ECU and check for moisture. Also, you can try a hard system reboot by holding the negative battery cable to the positive battery terminal for 1 minute, this will discharge the system memory capacitors and let the system reboot. Please let us know what happens.
Jul 23, 2022 at 4:08 AM
BONGO MINDANAO
My Mazda Bongo Friendee runs smooth again after an ECU/TCM replacement.
Sep 9, 2022 at 6:03 PM
  • 55,710 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Sep 10, 2022 at 7:38 AM
BONGO MINDANAO
Last question, at what water temperature should the 2 radiator fans start running? I found my normal driving temperature was around 75 degrees. Both my fans run with A/C on so that's fine.
Sep 10, 2022 at 1:52 PM
  • 55,710 POSTS
The fans should come on at 210 F. 98 C.
Sep 12, 2022 at 8:50 AM
BONGO MINDANAO
Sep 12, 2022 at 12:18 PM
SLIPMATT
Hi, if you don't mind me asking was the problem intermittent or permanent? We have a van with the same symptoms, however occasionally it will start normally but overheat - could it be the TCM, or something connected to it?
Feb 12, 2023 at 12:15 PM
  • 55,710 POSTS
BONGO MINDANAO our new member SLIPMATT has a follow up question for you?
Feb 13, 2023 at 5:50 AM
