So, the issue I have, is it seems on extended trips, at times, the blower motor will sound "louder" at the top of the dash. The speed itself does not seem to change, but when it sounds louder, nothing really comes out. This is not a switching issue, as it is already on high. Does not happen all the time, but often enough that I would like it fixed before winter sets in. I will say it is not giving the "normal" blower motor going out things I have experienced in the past. I would assume that if it sounds louder, the air should not be getting less... Just don't know. Could it be a block somewhere like a shop vac when you put your hand over the hose?
Oct 19, 2022 at 10:40 AM
