1984 Other Porsche Models 944 Power Steering Pump Removal
1984 PORSCHE
73,000 MILES • 4 CYL • 2WD • MANUAL
TREKINOUS
  • 28 POSTS
1984 Porsche 944 Non-Turbo, 2.5L Inline 4, 5 speed.
Is there anything special required to remove the power steering pump? Or is it a fairly straight forward on and off procedure?
Aug 29, 2008 at 1:27 PM
DOC762399
  • 8 POSTS
Removing the power steering pump is not a problem for most back yard mechanics. Now reinstalling a new pump is the problem. you need to make sure the timming belts are tensioned properly. There are two belts. a primary belt and secondary belt. If these are not tensioned right you damage the motor. The valves and pistons will hit. There are tools and proper procedures to do this. I have used a clicker tool from www.944online.com this is the easiest way that i know of. Good luck.
Oct 21, 2008 at 6:47 AM
