1983 Other Porsche Models No electric to fuel pump
1983 PORSCHE
160,000 MILES • 4 CYL • 2WD • MANUAL
TSLOAN
Have no electric to fuel pump. Checked fuses and have replaced fuel pump relay and fuses. Have new battery. Car had been setting in storage couple years and I drained fuel tank and put new fuel in. Removed cap at end of fuel rail to pump out rest of old fuel in system and pump will not work. With the key on there is no eletric at pump. While turning engine over and no electruc to pump. What should I do next? Thank you.
Jul 29, 2008 at 7:07 AM
MECHTRIX
  • 529 POSTS
unplug the fuel pump relay " then turn the key till you see the dash lights then go test the pump relay socket with a meter or a test light " if nothing " then it could be between the back of the ignition/key switch' and the pump relay .....also check that all ground wires are clean and tight and check behind the fuze block for corrosion or dis conected wires....i hope this helps ..."good luck"
Feb 4, 2009 at 3:00 PM
