1980 Other Porsche Models fuel
1980 PORSCHE
98,000 MILES • 4 CYL • 2WD • MANUAL
GMILL73
Plugs foul out as soon as it starts. When trying to start it after that gas starts appearing in the oil. This has a fuel distributor. Could it be my fuel pump is not producing a high enough pressure?
Aug 11, 2008 at 1:41 AM
DR LOOT
  • 2,311 POSTS
the fuel pump pressure may be an issue or you have one or two injectors that are staying wide open dumping fuel into the cylinder going into the oil you may also have a fuel pressure regulate problem.
Jul 23, 2010 at 12:06 PM
