2008 Porsche Cayenne Transmission
2008 PORSCHE CAYENNE
17,000 MILES • 6 CYL • AWD • AUTOMATIC
STEVIE DEE
I was told by a local tire dealer that I cannot switch my wheels from 21" to 18" unless I get the transmission reprogrammed. Is this true?
Aug 22, 2010 at 3:18 PM
CWPORSCHE
  • EXPERT
  • 58 POSTS
No, however if you have tire pressure monitoring you may have problems calibrating,also make sure you have the same overall diameter as the other wheels or you may have psm issues,and lastly make sure the wheels are the correct offset or the brake calipers may rub on the wheels.
Aug 25, 2010 at 1:25 PM
