2002 Porsche Boxster noise at the rear passenger side
2002 PORSCHE BOXSTER
50,000 MILES • 6 CYL • 2WD • MANUAL
SYLVAINSYLVAIN
Hello ,
When I am driving on side road I can hear noise at the rear right side , On the hwy Nothing but when the car isho after running more then 30 minutes it get more nosie .
I check the brake pad galiper , the suspension if something is loose did find nothing . Is it possible then the noise can come from the Realease clutch bearing ?
Jul 11, 2010 at 7:46 PM
CWPORSCHE
  • EXPERT
  • 58 POSTS
Could be a rear wheel bearing that is noisey. Jack up that wheel and spin the wheel, if it makes a growling noise,thats your problem.Might also be tire noise.Thers also a engine compartment cooling fan on that side but those rarely fail.
Jul 13, 2010 at 11:17 PM
