1998 Porsche Boxster Oil light is Flashing
72,000 MILES • 6 CYL • FWD • MANUAL
ZIGGSTER212
I have not used the car for 6 months and when I turned it on:
• The Oil light is flashing (blinking), however the engine’s temperature stays a tad above 180 degrees.
• Oil level seems to be OK it had a recent oil change.
Does anyone know the reason for the blinking of the oil warring light?
Jun 8, 2010 at 3:51 AM
2CARPRO JACK
  • 11,533 POSTS
I dont suggest running the engine any longer until a manual oil pressure gauge can be installed to verify that it does have oil pressure.It may just be a faulty oil pressure switch/sender, but until the actual pressure can be verified I wouldnt drive it or possible internal engine damage could occur
Jun 9, 2010 at 1:16 AM
CWPORSCHE
  • EXPERT
  • 58 POSTS
Oil pressure lights don't usually flash. Are you sure you are not looking at the coolant light flashing.Its the one to the right of the coolant gauge.It may be just low on coolant.There may be a coolant leak.
Jun 27, 2010 at 5:52 AM
