2000 Porsche 996 white smoke
2000 PORSCHE 996
85,000 MILES • 6 CYL • 2WD • MANUAL
JRKENYON83
Without warning white smoke suddenly began billowing out of both exhaust pipes. All temps and pressures are normal and check engine light is not on.
Aug 30, 2010 at 10:20 AM
White smoke normally is an indication of coolant burning in the cylinders also could be the crankcase oil saturated with fuel due to injector/s and fuel pressure regulator leaking
Aug 30, 2010 at 4:19 PM
