1990 Porsche 944 Oil Pressure Gauge
52,000 MILES • 4 CYL • 2WD • MANUAL
CHARLES JARVIS
1990 porsche 944 the the oil gauge on dash was fine, now it is all over the place up and down, nothing constant. The oil has been change recently and is clean. The low oil light is not on. Can you help me with this problem.
Aug 5, 2010 at 3:51 AM
  • 75,988 POSTS
Oil pressure:
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch. If abnormal could mean oil pump and/or engine bearing.
Aug 5, 2010 at 8:46 PM
